58 Sea Fury
- May 30, 2011
- 19
I bought my first I/O so I'm new to I/O boating and have little problem solving knowledge. I'm hoping I can count on the good people on iboats. I have a Mercruiser Alpha One that has a small trickle of water that leaks in only when it is trimmed all the way up while trailering. Once I trim it down at all it stops leaking. Any idea what would cause this? Do I need to replace the bellows? Do I replace all at the same time? What would be an estimated cost for the solution? Should I trim it down when stored?The boat is a 1999 Larson 206. Thank you for any help!
