Re: leaking built in tank
Thanks --<br /><br />I began to smell gas in my garage -- didn't realize it was coming from the boat. when I went out on the water, though, I noticed the smell coming from below when i removed the bilge cover. Back at home I pulled the main plug and about 2 gallons of gas/water mixture came out -- hard to tell how much of each, but plenty of gas. <br /><br />The boat's been sitting in the garage for a few days, now, though, with the plug out and a bucket below, but not a drop has dripped out. <br /><br />I'm wondering if the leak might occur only when the tank is very full, or when the engine's running.<br /><br />Even though it doesn't seem to be leaking now, there are still lots of fumes. I'm trying to keep it well ventilated.<br /><br />I know where the tank is - right under the helm in the center. I did replace the sending unit not long ago, but that doesn't seem to be leaking. I can't feel any moisture around the top of the tank.<br /><br />Could a normal boat garage run a pressure test on it??<br /><br />Thanks!!
