scout-j-m
- Jul 31, 2009
- 643
Fuel leaks from my float bowl when I tilt my 1994 &0HP Force up. The float and inlet needle seem to be set right as I can pump the primer bulb until lit gets very hard and not force any fuel to leak from around the bowl nor come out of the overflow weep hole. Not a lot appears to be leaking but enough that if I tilt the motor up and haul the boat to the lake I would imagine it would eventually leak into the cowling some. The bowl gasket is a new OEM one (looks like it is cork). Are these cork ones always going to let some fuel seem through them or do you think I have a another issue causing this other than a leaking gasket?
