Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Hello another question for my 2001 25hp Johnson (J25TVLSI). I have a leaking fuel hose. I dont think it has a specific item number or anything like that. So how would I go about getting a replacement? Thanks for any help
Unless it is a specially molded hose I would just go to any auto parts store and get a hose of the same inside diameter. Other will chime in with more suggestions. Good luck
Ok thank you. Tried a couple Auto part stores with no luck. Ended up getting one with as similar of a inside diameter as possible from lowes. How crucial is it for it to be exact? Thanks
Depends on if its sucking air or not?
Doesnt look like its the main hose, or the pulse hose, so its the 5/32 smaller stuff.
Johnnyrude part # 0327228
Should need less than a foot of the stuff @ $2.70 a foot.
