I'm putting my Johnson 150 back in operation after a 2 year break.
. I noticed the fuel rails were leaking gas when I pumped up the bulb so I removed one side to repair it and I cannot find the O rings that fit it anywhere (its the weekend). It looks to be about 5mm inside dia. x 3mm thick. Has anyone found these O rings without going to the boat dealer? The O ring is fat for it's size. I can find plenty rings that have the inside dia but they are just a regular thickness. The fuel feeds from a center mounted fuel pump to the two fuel rails (1 on each side of the engine) that feeds fuel to the throttle plate for each carb.
The carbs were rebuilt the year before I used it last so I'm going to see if they run ok before I do anything else. Also, what type of grease should I put on these O rings.
