jitterbug127
- Feb 6, 2023
- 636
Metal omc tank. Cleaned inside really well replaced gaskets. Now it’s leaking in multiple places I’m not sure why. Pretty simple process, not sure where I went wrong.
Yes! I guess the plunger isn’t sealing anymore when the tank isn’t connected. This is new since I cleaned the fitting itself.It is "leaking" from the place where the fuel comes out. When you connect the fuel line, that plunger unseals the tank, allowing the fuel to flow into the fuel line. I do not know if there are repair kits for the fitting itself.
Ayuh,.... The o-ring seal on the outlet is leaking, no compound is going to change that, you need the o-ring,....I don’t think gasket was damaged, but it is leaking under the unit. I cleaned all the old paint and lightly sanded both tank and unit to get proper seal. Could I add some compound to help seal it is this going to make it worse?
I always unplug the fuel line from the motor when done. If there is a leak, I want to see/ smell the fuel so I can fix the issue. Leaving a fuel line plugged in to the motor can cause issues, if fuel hose has any pressure built up.Sure, buy the repair kit and do it right.
Or,.....in the mean time leave the hose attached to the tank, but not attached to the motor.
Looks like the kits I used to buy years back. There have been a couple occasions where I needed more than one gasket under the fuel outlet.Kit like this? I already replaced the big gasket the smalll rubber gaskets and the little paper one
Yes, of course, that's OB Motor 101. It's also advisable to let the motor run when it's unplugged to drain "most" of the gas out of the carb.I always unplug the fuel line from the motor when done. If there is a leak, I want to see/ smell the fuel so I can fix the issue. Leaving a fuel line plugged in to the motor can cause issues, if fuel hose has any pressure built up.
Second gaskets are not the norm. Maybe your tank is dented at the fitting place.I might need a second gasket under my fuel outlet. That wouldn’t shock me at all. Once again y’all have been super helpful. I’ll order the kit and replace the o rings. I’m sure YouTube video somewhere.
