Leaking gray fluid at fuel pump
Bratcher4079
I have an 89 valiant VIP that is leaking a light grayish colored fluid from where the fuel pump block off plate (it has an electric fuel pump) seals to the block. The motor is is a 4.3l GM V6. I assume this is oil and water but I'm not sure. There isnt any water indications on the oil dipstick. Could this just be condensation?
Bratcher4079
Re: Leaking gray fluid at fuel pump
Can someone please help me with this question????
HorizonblueDK
How does it look, when you open the oil fill cap?
Bratcher4079
I looked in the oil fill cap and it looked very clean. However there some moisture drops on the rocker arm that I could see. Using a flashlight I could see a couple of lifters and the had the same grayish fluid pooled on top of them. It was a small amount. The dipstick looks very clean and there doesnt appear to be ony moisture on it.
HorizonblueDK
In this case, I wouldn't count too much on the dipstick. When you have this grayish fluid on the rocker arms, I guess you have water in the oil, and a leak somewhere. But start by changing the oil, and see how that looks. Then take a trip or two and see if the grey stuff re-appears.
