leaking lower unit
billburleson
I have a 1994 120 hp force and it has started leaking from a factory hole above the prop. Do I have a seal out and any idea which one or more it may be if its a seal.I have a fairly good manual but its not showing this hole or what it may be. can anyone help?
Jiggz
Re: leaking lower unit
Can you post a pic? Those holes on the bottom of the cavitation plate do have a purpose and usually it's to drain water leaking from the water tube, water that got in through the shift rods, etc.
