Leaking Outdrive Oil
RonCzyz
I'm having a problem with Outdrive Oil leaking out of a vent hole on right side after changing the gear oil. Have any idea why it would be doing this? It's a 2002 Mercruiser Alpha I. Thanks.
crazy charlie
Re: Leaking Outdrive Oil
Did you split the drive in 2 ???? Was there any water in the old fluid??? foam?? Creamy crap????Lube that went in dark green and came out light green???Charlie
