leaking power steering fluid ?
markn88
So I've taken my new used boat out a couple times now and everytime I bring it back I see some liquid on the floor . I don't see any holes in the power steering reservoir ... Where else can it be leaking from .IMAG0085.jpg
bridweezul
Re: leaking power steering fluid ?
There should be a rubber seal in the cap that can get old and wear out. Check that. Also, check the hose where it goes into the resevoir. That can also wear out.
If the resevoir was cracked the unit would leak consistantly as well.
ta,
markn88
ok just looked, there is no seal under the cap. i kept tighttening hard and it must not be making the seal ill get a seal in there and see if that fixes it.
thanks a lot
So I've taken my new used boat out a couple times now and everytime I bring it back I see some liquid on the floor . I don't see any holes in the power steering reservoir ... Where else can it be leaking from .View attachment 96283
Ayuh,... That's the trim pump tank, Not the P/Steerin'...
Get a new cap for it...
markn88
Humm... Alright then new cap or seal it is .. thanks guys
Bt Doctur
normally the level is about an inch below the cap with the drive all the way down.
markn88
well it looks like it might be over filled then because the drive is down and the fluid is almost to the top
Don S
No wonder it leaks. the bottom of the seam in the reservoir is the full mark.
