A buddy of mine has a 16ft aluminum john boat that is leaking at some of the rivets. Is there an accepted or standard way of fixing this. If not is there a non-accepted or non-standard way of fixing this.. <br /><br />Thank you all....
You can use Gluvit to fix the leak from the inside or 3m 5200 to fix it from the outside.If it seems like the rivets are no longer doing any "holding" then they should be replaced.Charlie
