Leaky water pump & Hot water....
JETFAN123
I have a 1998 Bayliner 2050SE with a 5.0 220HP Mercruiser.<br />1. Water is accumulating in the bilge the last 2 times I went out, figured it was from all of the water from the skiers/tubers getting into the boat soaking wet. But then I noticed that the little hole on the water pump had rust traces and buildup in and around it. Suspect it is the source of the water, but no proof.<br />2. When flushing in the driveway, I noticed the port side exhaust water is a lot hotter than the other side. The first ime I thought it odd, the second time I am now fearing a problem.<br /><br />Are these related?<br /><br />Recomendations....<br /><br />Wanting to get out a few more times in Jersey!
Northern Eclipse
Re: Leaky water pump & Hot water....
If water pump is leaking from weep hole, thats your warning shaft bushing is worn,pump needs to be replaced, port side water being a little bit warmer is O.K, but you should be able to put your hand on the risers and hold it there, if to hot to the touch, then you have a cooling problem, but I doubt a little weeping form water pump would have much to do with it. If you boat saltwater, at the least I think its time to remove manifolds and riser, have them inspected and replace if needed, a rotted or plugged riser will be to hot touch, also what is your current running temp.
MFG197
i plan on replacing my WP also 5.7Lx 250hp merc.<br />water dripping. <br /><br />I did also notice one riser hotter than the other in the driveway, not real hot, but hotter. doesn't seem that way when its in the water though...<br /><br />also, let me know if you find a deal on pump... i will do same
mjs22
Just replaced my water pump on a 4.3L Volvo Penta. Prices vary dramatically and I found good prices and customer service at boatfix.com. They sell sierra waterpumps. Arrived in 2 days . FYI.
MFG197
thanks mjs...i'll look!
