Lean Pop....or sneaze?
DirtNapp
I have a 1965 18 hp evinrude fast-win. At idle it has a hiccup or sneeze or pop. When I am running WOT it does not do it, it runs awesome. The guy where I buy my boat parts from said it was a lean pop. I was buying points and condensers for it thinking it was a firing problem. Is it as simple as running lean? I don't want to pull the flywheel if it is not necessary.
Thanks in advance for any and all answers. By the way, this is an awesome site.
Glenn
bktheking
Re: Lean Pop....or sneaze?
Should have a knob to adjust idle mixture try adjusting it.Tf it has no effect the carb is probably dirty.
DirtNapp
I will do that. I saw the article you wrote about how to set it. Just maybe I will be taking the points and condensers back.
bktheking
Points and condensors is spark, verify you have good constant spark before you return anything, you may end up needing them. Article I wrote????
DirtNapp
I thought it was you that wrote the article in the FAQ about points and coils. My bad if not. But hey thanks anyway for the info.:D
DirtNapp
Re: Lean Pop....or sneaze? Update..
Can you say kitten? Well that is what she is like now. Purring like a kitten. Ya hoo! I will save the points and condensers for another time, not needed now. Again Thanks.
bktheking
Kitten :D
