Lean sneeze!
ifishhard
Ok, now that i know that the "lean sneeze" is from your motor running to lean. SOOO does that mean if my motor is not "sneezing" at idle i am not running lean? I had to idle a good ways yesterday and it did not "sneeze" one time! So im not running lean????:confused:
R.Johnson
Re: Lean sneeze!
That's it. if you are running with a good steady idle, your good to go.
PmDavis300
Re: Lean sneeze!
what exactly is a "sneeze" meaning, what does it sound like... and please dont say a sneeze :)
fishnhunt
Re: Lean sneeze!
Is there a such thing as a "rich sneeze" OR at idle, what are some signs of running too rich?
F_R
Re: Lean sneeze!
A lean sneeze is actually the fuel igniting in the crankcase. It would backfire out the carburetor if it were not for the reeds stopping the explosion from going in that direction. It sounds like a hesitation with a muffled misfire. A clunk and shake.
No such thing as a "rich sneeze". But running too rich will cause it to missfire and foul plugs. That is more like a simple skipped beat without the muffled clunk.
Gary H NC
Re: Lean sneeze!
I have been fighting finding the cause of my lean sneeze with Rodbolts advice. Carbs rebuilt,closed off idle air bleeds to check them.still no luck finding the cause...:(
R.Johnson
Re: Lean sneeze!
The engine sounds like it is making a muffled backfire. With the airbox cover off, you can see a spray of mist come out of the carb throat. This most always means a lean carb, or the engine is drawing air from another source increasing the fuel, air mixture. A lean mixture thru the idle circuit can mean just a sour running engine, thru the high speed circuit, disaster. A rich running engine most times will just be a rough idle, and the engine flooding itself out. The engine can also make, for lack of a better word, a blubbering sound, almost like it is four cycling.
dave828
lean?? help please
lean?? help please
:confused:ok. can somebody please tell me about lean and how to fix it! My 5hp yamaha kicker outboard has been sneezing (revving up and down when in gear) then stalling. after stalling it would take me 5-6 pulls to start it.sometimes it wont start with the choke off (when hot).It might not even run with the choke off (in gear).Ive rebuilt the carb and still it starts it's ****!ive had a similar problem with 2 of my yamaha 150hp outboards at different times,but one of them strangely fixed itself. please can somebody help me please thank you!
Dhadley
Re: lean?? help please
If a motor does not "sneeze" at idle it only means it's not lean at idle. It very well could be lean at wot, mid range or even at 1000 rpm.
wilde1j
Which, of course is VERY bad!
