Led trailer wiring
Lsfishon
I recently switched my standard lights to LED on my small boat trailer. Old lights had standard two wire connection. New ones have 3. Green, black,red. Only info was green to brake. Red to positive, black to negative.
Here is the problem. When I turn the headlights on, the marker lights(spliced into brake line?) work but nothing else will. With headlights off, all turn signals ,flashers, and brakes work. I didn't do anything to the wires except try different configuration connecting the two wires to three. Thanks for any info.
Powerstroke in a Prius
Is there a model or part number on the light kit? This sounds like the instructions may very well have had a translation issue.
briangcc
It sounds like something is mis-wired. Standard 4 pin? Here's the diagram...
Lsfishon
Ok how about this. New LED lights have three wires coming out. Directions say red is positive, black is negative, green is brake. What do I connect to positive and what do I connect to negative? And when I clamp my tester and touch the frame, the light goes on but it doesn't when I poke the wire. Hhhmmmm???
Lsfishon
I'm familiar with two wire diagrams. They all have yellow and brown and green. No diagrams that I have seen tell you how to connect the red, black, and green wires from the LEDs to the brown , yellow, and green wires from the trailer
GA_Boater
Someone asked earlier what brand of lights?
Guessing;
Green light wire to green wire on right side, green light wire to yellow wire on left side - Those are the brake/turn lights.
Red light wire on both sides to brown for tail, marker and license lights
Black to ground or white wire from the flat trailer connector
briangcc
Actually I think GA hit it on the head as the LED's probably have a couple circuits on board to control the different functions/brightness required.
This could be confirmed by a call to the manufacturer or by posting up what kit was purchased so we can try to reference the manual and make heads/tails out of it.
GA_Boater
Nothing fancy about how they work. LED trailer light brightness is controlled by the number of powered LEDs. Tail lights might be 3 or 4 LEDs and brake/turn is twice or 3 times more. The brake/turn LEDs may emit more light depending on the design. So wiring the lights is the same as incandescent filaments.
roscoe
I would really like to see info on these lights.
Brand ?, type, advertising ?, link ?
Intended uses ?
Have you tried what GA posted in post number 10 ?
Blind Date
+1 - I've converted both my snowmobile trailer and the the trailer under my SeaRay to LED. They wired exactly the same way as the incandescents. The only lights that should've 3 wires are your tail lights(Ground, power for running lights, power for brake & turn signals). Your running/marker lights should only have 2 wires. If they have 3, they are not running/marker lights.
dingbat
I did this a couple of months ago
Red marker lights (splice) goes to Brown. Black to ground.
Green (brake wire) goes to green and yellow on trailer. Black to ground
Red (positive) goes to Brown. Black to ground
