Lenco trim tabs flashing on right side
SkaterRace
Master Chief Petty Officer
I have a CC with Lenco trim tabs and have recently had them stop working nad start flashing on the right side of the control unit. It is the bottom lights. I have not a clue what it would mean. Issue happened after sitting for 3 days at the marina. No physical damage that I can see from an impact or something like that.
check voltage. they flash for low voltage
¯\_(ツ)_/¯
I googled the flashing lights, it said low voltage
SkaterRace
Went down to the marina today and checked voltage. Ended up being voltage and the cause of it was a low battery. Low battery was caused due to how the new charging system I have in is configured/made. I have to remember to configure a setting on it each time I put the boat away OR let the engine run for 1-2 hours while not using a ton of power.
