pecheux
- Jun 9, 2006
- 1,200
I have been reading pros and cons regarding usage of synthetic Amsoil Saber at 100:1 ratio and even lubeman (amsoil dealer) seams sceptic about Amsoil even producing that kind of oil designed for lean mix. Personaly I think AMsoil top man (forgot his name) had (and has) vision about extreme air and water polution by 2 cycles outboard engines and meant to produce and oil that would cut down on air and water toxicity by making it richer so as to use it at 100:1 ratio.<br />Well that just my way to phrase it.<br /><br />Motor were built for a 50:1 mix ratio ... BUT that's with using conventional 2 cycles oils. Seems that what was designed here with the Saber Outboard 100:1 mix ratio is a different type of oil that would lubricate as much as a regular oil at 50:1<br /><br />If that is THE fact ... then most arguments I have read are meaningless. Too many outboard owners have used it in both big and small outboard motors to say the product does not deliver. <br /><br />Nevertheless I presume that this does not mean that Amsoil has to be a better oil althought it might be ... it just means it was designed to do the 50:1 job at 100:1 That's what I think I have read all related posting.<br /><br />Also I am not surprised that AMsoil recommends using the Saber Outboard oil at richer mix for racing motors and commercial usage. (80:1 & 50:1)<br />Race cars and trucks have some of the same higher requirements for their oil also. I presume most of us here on these forums are using pleasure crafts for sunday runs and weekend fishing. <br /><br />I think it is reasonable that others that run the ocean for hours at WOT use a richer mix with Amsoil just as they should run 40:1 to 45:1 with regular TcW3 oils (as per my merc mecanic)<br /><br />Perhaps using lean mix that could reduce engine life is the price to pay to show our care for this planet. We do run expensive anti-polution devices in our cars that reduces power and performance. What is wrong with doing so with outboard motors if this is the case ?<br /><br />May I note here that I was slighly disapointed with the statements from lubedude as he mentioned a few times that he wished Amsoil would stick with the Injector oil at 50:1 He is probably tired of having to explain the benefits of using that Saber 100:1 oil to those who dont understand the chemical behind it. <br /><br />Anyway I would like to have comments regarding the cleaner air and lower water toxicity behing the usage of the Saber Outboard oil that was designed to be used at 100:1 mix ratio for what I suspect is exactly that purpose.
