I need to replace the leveling cable sheaves on an old "Station Master" 2600# vertical lift. I can't find any information on "Station Master". A Hewitt dealer in the Finger Lakes area told me today that the company did exist and built their own lifts. It looks like a knock-off of a Hewitt lift to me. I am the third owner. I think one of the previous owners "repaired" it with steel sheaves assuming the manufacture would not have used steel. The 4 sheaves at the ends of the tubes running front to back support a cable that is tied to the lift bottom at the front where the winch is and to the top of the lift at the back. This is same as the 5 cable Hewitt configuration. The sheaves that are in it I measured to have an OD of 4.382, and ID of the center race of the SS ball bearing of 5/8 (0.622) a groove depth of about 0.328 and a width of about 0.550. You can see from the pictures that they are pretty badly rusted so I measured them the best that I could.
Assuming these were not the original sheaves does anyone know what was likely in there? The axle holes in the rectangular tubing are now oval or egg shaped but but I think there were centered vertically and 1.25" in from the end. I'm planning to insert some 1/4" plate with a 5/8" hole drilled in the right place inside the tubing on either side to fix the axle wobble but I need to find a replacement sheave. (I want to try to repair this without taking the lift apart and I don't think I could drill a bigger hole with a hand drill for a bushing) I've seen some much wider sheaves that look to me as though they might hold up a lot better. Right now the cable adjustment at least on the top is pretty close to the max (not sure about the eye under water). So a smaller sheave probably means new cables too which I will probably have to swage myself since there are no "spare parts" for this lift as far as I can tell and of course I don't have a swaging tool.
The best replacement that is pretty close to what is in there is http://www.boatliftanddock.com/p-295-shorestation-ball-bearing-pulley-3510178.aspx. The problem is that it says the ID of the bearing in the middle is 0.98 If that is right there is no way I could press fit a nominal 1" axle or spacer in.
Any information on the original lift construction and how to repair it?
