Lift pump has no power
1dumbazz
Hello everyone I had to take a break from the boat but I’m back lol
here is my question
i have a 2001 evinrude ficht 150
i put a test light on both wires going to the lift pump and it’s not lighting up first question should it
second question if it’s supposed to light up what should I check or do
I have tested all the relays and all the fuses what now?
oldboat1
Battery connected (and correct polarity)? Key on? I think the fuel pump is electric, but the lift pump probably would not be -- mechanical pump getting it's pulse from the fuel pump.
1dumbazz
Yes battery is good the fuel pump goes on for about ten seconds but the pump is bone dry and the lift pump gets no power from either wire connected to it no noise or anything I was thinking about connecting a low pressure fuel pump between the fuel filter/ water separator and the fuel pump just to see what happens any thoughts on that?
Faztbullet
STOP!!!! Get a FACTORY manual on this motor. The lift pump is a mechanical pump and has no power or wires to it. The only pumps powered is the oil injector and water cooled fuel.
oldboat1
No, that doesn't follow. The lift pump may or may not be working properly, so could be an issue -- haven't ruled it in or out.
I think I would look for blockages first. Think fuel filters and pickups/pickup screens. Blow out fuel lines, perhaps.
Faztbullet
Where are you testing/looking for fuel???? Whats motor doing? Better hope it not fuel pump as that a $900 part...
