reavesga
- Feb 14, 2010
- 165
I have a 1974 OMC 3.0L motor that I have since converted to mercruiser. Over the years it developed a clicking sound that was very much like a lifter so I decided to replace the lifters. Now, assuming that all of the 3.0 motors are pretty much the same I went to the mercruiser book and found that the lifter part number is 46744 replaced by Siera part number 18-1402. I ordered 8 of them and when they got here I installed them. Now I noticed that these were squishy as I would expect from a hydraulic lifter. however the ones I took out looked the same but I could not press the top of them in at all. Anyway, I put the motor together, adjusted the valves, and tried to start her up. All I get is the random backfire or the random cough through the carb. I am assuming the problem is in the valves, but before I go crazy adjusting the valves, are the lifters just the wrong part for the OMC 3.0 motor? They physically look identical I just can not push the tops down where the rod goes and I can push it down, albeit with some effort on the new ones.
The other thing I noticed is that as I was adjusting the valves, I never could seem to get the push rod to quit turning. I have always just use the push rod stopping rotation as the place that the valve is adjusted. Should I just keep cranking till the rod quit turning. Any experience here is greatly appreciated.
