Re: Lifting the top, what's the best way
if it is not glassed together, the worst part is freeing the stearn, and the floor of the bow , basically gentle prying, you can work alone or with a helper, and get it freed up all the way around, some pieces of 1x2 4" long can be inserted between the top and bottom as you work, then get the boat out of the covered area, get the neighborhood together for a cook out, but to eat they have to help you lift the top out of the boat. support it all the way around. i would say safely 6 or 7 people.
when you put it back together is suggest filling the drain hole in the engine splash well and installing drains on each side of the engine.
