I have a 1989 Evinrude 70 on a Tracker 17' Tournament.  Problem:  I replaced the tach light (other one was missing).  Light does not work when I flip on the dash lights (all other guages do), but when I insert the ignition key and turn it to on the light works even with the toggle switch off.  Additionally, the tach needle floats to about 1000 rpm when ignition is off, but drops to zero when it turn on the key. The guage registers rpms fine when the engine is running. <br />Was wondering if all this is normal, especially with the light working the way it is.<br /><br />Thanks, Cal
