Re: Lights not working
Shouldn't you have asked this question "before" you bought it. If the engine happens to be an Evinrude "FICHT" you may have purchased a problem. Checking here would have spared you that pain. You may have a good one however so good luck.
As for fuses, you may not have any. If there are little buttons along side, above, or below the various switches, those are circuit breaker reset buttons. Push it to reset. If they are not tripped, or if you do find fuses and they are ok, the wiring between the switch(es) and the lights is disconnected. I suppose you've checked the bulbs??????
