RaceCarRich
- May 31, 2015
- 234
Went to winterize my 2000 Bayliner 3.0L, took off the cover in my driveway and saw water. Pulled back the engine cover and the bilge is filled up to almost the oil pan rail. Starter is probably 85% submerged. Water on top of plastic fuel tank. Apparently some wood splinters and stuff clogged the garboard plug hole. My bilge is not a filthy mess but the boat is always shedding some. How splinters can form a water tight seal that holds back many gallons of rain water, especially in a tilted driveway with bow up, is amazing. Turned on bilge pump and poked the plug hole free with my finger.
Checked oil - clean. Hit the key and starts right up then dies. Figured some water leaked into tank. Pulled line from carb and cranked into bottle. Separated to about 1" clear floating on top of cloudy. Pulled the fuel fill hose which enters top of 23 gallon tank at an angle, inserted hand drum pump. Pumped about 4 gallons into a bucket, poured into barrel. Pumped another 3 gallons into bucket and noticed it was perfectly clear. Added stabilizer and topped off tank and started. Ran for solid 20 minutes varying throttle before fogging carb and draining. Hit starter connections w WD40 and said goodnight.
Starter sounded fine throughout but do you think it will be dead or die next season? Only 1 year old.
Not sure how much water dripped through sender gasket but I'm hopeful I got most of it by draining from back bottom corner. I'll add some heet next season. I also think the stabilizer has some dewatering attributes. I read the other thread going on about water in fuel. Should I be overly concerned at this point?
Any other things to be concerned about mechanically?
