Limited Trim Travel
edcarman
I just purchased a 2007 Sea Ray 200 Select with a 5.0/Alpha Mercrusier. The trim will function both up and down but only for a short distance from the full down position. Fluid appears to be at proper fill level. Any thoughts?
Bt Doctur
From full down the trim limit should stop at about 20 -1/2 inches of ram travel, from there trailer button raises it the rest of the way
edcarman
Probably didn't make myself clear, trim travel from fully lowered is only about 3-5 inches. No ware near full up.
Bt Doctur
Then the trim limit puck needs to be loosened and rotated to allow more travel trim limit is 20 -1/2 from nut to nut,
then trailer takes over
edcarman
Boat is equipped with the Mercrusier digital gauge package. Could I have simply mucked up the setting when fooling around in the "trim" area of the settings?
edcarman
Should probably change my user name to landlubber. SmartCraft manual indicates where I probably messed up during calibration. Who knew you could solve an issue by reading the directions, oh yeah my wife! Thank for your help, I'm sure we will talk again.
