Re: Link and sink what the heck is that
Hi Mike. <br /><br />What it is, is, link and sync. It's adjusting the timing of the engine with the opening of the throttle plate.<br /><br />If you look under the flywheel, you will see a black plastic cam which will contact that little roller connected to the carb throttle plate thru a link. On that cam, there is a little hash mark. When the hash mark is dead center of the roller, the throttle plate should just start to open.<br /><br />If this gets outta wack, along with that long rod going back under the flywheel to the throttle tower, the engine won't run as advertised.
