SkiDad
- Jul 18, 2010
- 1,518
1985 Force 125
OK, so i never have fully checked the link and sync on my engine except for the fact that the carbs both opened fully at the same time. Well the lower carb opened up just a hair past flat. But it always accelerated very smoothly.
Anyhow out of curiosity, i unhooked the ball link at the tower, and thought I would check where the cam touches the roller. the bottom line hit about center to the roller.. so I adjusted the eccentric screw on the roller so it hit between the 2 lines - not a huge amount of adjustment. Seemed to make the bottom carb open up about dead flat (again not much of a change)
here is what I noticed on the water yesterday -- it didn't accelerate as strongly or smoothly - everything is slower - 4000 rpm is now 25 mph instead of 28. But WOT jumped from 5200 to 5400 but speed dropped 1-2 mph.
I just can't understand that result at all - the only thing i really changed was loosening and re-tightening the bar link and that eccentric screw - before I put it back can someone explain what changed and why ?
