1983 Johnson 70hp Seahorse. Had carbs rebuilt, new plugs, compression checked ( all cylinders good ). Mechanic changed part (see 1st and 2nd pics ) which was homemade..back to an original part ( see 3rd pic ) . Previous owner had replaced bottom end (4th pic ) . Took to water today. Giving it forward throttle puts it in reverse. Reverse throttle puts it in forward. Writing on the bottom end ( 4th pic ) says "shift rod down = Fwd R/H ROT". Is there something in the bottom end that could be wrong? Am clueless here. When the homemade part was on, no problem in forward / reverse. Also noticed oil leaking from the propeller shaft..what's up with that ? Thanks in advance..
