Elk Chaser
- Jul 29, 2003
- 186
First some background. <br /><br />Bought a Baja boat with a recent (25 hours) rebuilt 454, fairly high compression (11.5:1 or so) and after a few runs it burned/blew the head gasket on the starboard side. Turned out that the head gaskets were really cheap and I had them both replaced with some quality stainless steel ones, mechanic also found a couple stripped out head bolt holes and repaired those. Heads were true as was the block and everything else appeared to be in good shape.<br /><br />Ran great for the remainder of the summer, about another 25 hours or so. But, the last couple times on the water when it was fairly cool outside I noticed just a little bit of steam (was not smoke as it dissipated fast) coming from only one side of the transom exhaust, opposite side from the blow out. <br /><br />I'm getting ready to winterize the boat but thought I should maybe take it back to the mechanic that did the head work and make sure that there are no problems before I winterize (getting cold fast around here).<br /><br />What do you guys think, is it something to worry about? My brain says yes but I thought I'd get some other opinions first.
