H2O DVL
- Feb 7, 2016
- 40
My boat, '05 Glastron 175SX has a ski locker that is slowly filling up with water, even though the boat has been on a trailer and in a garage since November of last year. There's a few small surface chips along the very bottom of the locker where the water is seeping in from. Just noticed this recently, likely because I have the bow down doing some other work, so the water that obviously is trapped in between the inner & outer gel layers is slowly making its way forward and coming up through the locker.
Now, if I'm correct Glastrons are all fiberglass so I shouldn't be concerned with any rot anywhere, but where is the water likely getting in? There's a few superficial scrapes on the hull, but I don't see any water running out, so I'm assuming that can't be the entry point. I'm resealing the drain plug (on the transom) but I can't see that being an entry point.
The ski locker does get some rain water in it (when the boat sits outside in the summer) so maybe over the years the water has gotten in (through the chips in the locker) and run back since that's the normal attitude of the boat. I'm guessing here, but I never would have thought that a fiberglass boat would trap this much water. I've already soaked up easily 3-4 liters in the past few days. It just keeps seeping up through the chips.... Thoughts? Suggestions? Advice? Thanks!
