I have a lowe Angler 150s and I flipped the switch to fill the live well while out fishing and nothing happens, I don't hear the pump kicking in either. I looked up under neath and the lives and connectors look fine, followed the wires over to the panel where the fuse is and both fuses are not blown. I assume that the live-well pump would be by the transom and probably on the other side of the bilge pump. is there a way to check to see if the pump is bad or something else?
