If my memory serves, on my 86 Skeeter F-80 15' both livewell pumps were located at the transom along with the drains for the livewells... <br /><br /> Look at the tramsom from the outside.. You should see five holes realitively close together on the transom... One is the drain plug hole for the bilge area, the two large ones are the livewell drains, and the two smaller ones are the livewell pumps... Both pumps should be accessable through the rear deck hatches...<br /><br />If memory serves?... Good luck...
