Not normal. Yes, you will eventually sink the boat.<br /><br />You have a drain or fill hose connection problem.<br /><br />When filling, start looking for leaks!
A good way to find out where the leak is coming from is to add food coloring to the water you add to the live well.<br /><br />The colored water will be easy to spot and trace...
