Live Wells
TD_Maker
I have a Whaler Mauntauk, and if you know older Whalers, you know there are no live bait wells(Or storage either.) I really need to build or make a small recirculating live well that will draw water from the outside. Any Ideas?
D
DJ
Guest
Re: Live Wells
TD,<br /><br />Unless you want to "drill the hull", which I DO NOT recommend, you have no choice but to throw a hose overboard, for fresh water.<br /><br />If you MUST, the bottom of the transom, is the best place, for an intake.<br /><br />I suggest, you consult these guys.<br /><br /><br />www.continuouswave.com
roscoe
Re: Live Wells
Do a search in the megamall for a "Basspirator", pump, hoses, fittings, thru hulls, airator.<br />Install it in the cooler of your choice.
