livewell/baitwell installs...
ShawnQ
I searched for both, and the only thing I could really find was 'home made' stuff, like ice chests turned into baitwells, etc..<br /><br />I am building a boat, and I have 3 or 4 areas that I can put baitwells. Of them, I want at least 2 aereated containers for bait (shrimp or finger mullet).<br /><br />I want the type that I can flip the switch and it will fill itself, and it will change it's own water with water from outside the boat.<br /><br />How is this accomplished? Any good 'kits' that you can buy?<br /><br />Thanks for any help.<br /><br />Shawn
rickdb1boat
Re: livewell/baitwell installs...
Try this Shawn:<br />Go to Marine, then Livewell/Aereators.<br /><br /> Cabela's
Valv
You can also try www.kvesurplus.com<br /><br />there are many livewells, pumps, etc.<br /><br />You will have to get a little "creative" since it will be tough to find something exactly for your boat, unless you try mfg. and it will cost a lot.
miloman
hey there Shawnq I just went through the whole process 3 options stainless steel aluminum or rotationally moulded plastic any way you cut it there is no kit persay you will have to determine the dimensions insert the pumps run the lines power supplies airators drains yourself trust me when I say there are no real options if you get stuck let me know Ill giude you through it
