Re: livewell troubles
Take a look inside your livewell and see what kind of spray head you have. Some boats have a plastic "pipe" about 6-8 inches long with holes in the pipe every 1/4 inch or so, these are not adjustable but can plug. The other type of spray head is adjustable and of you turn it in far enough you will totally close it off. This spray head won't be very big, it basically comes through the side of the live well and there will be what looks like a knob that you would turn with your thumb and forefinger. If you have this, give it a few turns counter clockwise and see what happens. you use the "knob" to adjust the amount of spray or water coming into the live well, , , especially if you have two wells fed off of one pump. My Lund is set up this way.
