I am in the process of installing new everything, but the hull, in a 1988 Bayliner bass boat.<br />The drains and overflows to the livewells were plumed together and this one hose then exits<br />the transom on the bottom below the water level. My question is how does the water<br />drain via the overflow fitting when your siitin still and not underway? In other words how do<br />these livewells work? I want to wire mine with a timer switch such as the one in Cabelas.<br />This web sight rocks and thanks for all the help. The Smeeb
