Livewll ???'s
poolshark38759
i was wondering if i had to use thru-hull fittings in the catolags like cabelas or bass pro?? could i use some for the poly tanks like ona spray rig.. they look the same just a little heavier built and thicker gaskets..
roscoe
Re: Livewll ???'s
If it will be below the waterline, I would use one that is approved for it.
poolshark38759
Re: Livewll ???'s
ok. these mount in the bottom of a spray tank so i figure they would be ok..
