I have a two beep warning going off on a mercruiser 350 tow sport.
The items i have gauges for are engine temp, oil pressure and volts which are all reading ok.
The warning seems to go off some times then stop going off for a while then may start up again later.
In the manual I have found these items listed as possible 2 beep/min warnings for the 555 ecm engine system.
-engine coolant temp circuit hi/low
-electronic spark timing
-fuel injector wire open
-iac output hi/low
-knock sensor hi/low
-map sensor hi/low
-oil PSI circuit
-sea pump circuit hi/low
-TPS 1 circuit hi/low
-5 Volt Direct Current PWR Low
-Manifold Air Temperature sensor hi/low
-Shift Switch
I do not have a scan tool. Is it possible to somehow locate each sensor and determine which one is making the alarm go off.
If so how would you test for the sensor in question ?
-iac output hi/low
-map sensor hi/low
-oil PSI circuit
-Shift Switch
