Locating fuses 2006 susuki 70 jp
upperwater
Not getting any power to my electric fuel pump. The pump itself is not working and must have blown fuse. Can only locate 1 fuse. Any one have this motor that could help. Found the one in the little white box in upper right of picture
upperwater
Fun Times
Is your engine fuel injected or carbureted?
Do you have an "owner's manual" from when the engine was new?
Typically help locating a fuse will be in an owner's manual much like your car...As an example, the following link is for a Suzuki DF70A Owner's Manual pages 71/72 that covers fuses for this fuel injected engine model..., https://www.manualslib.com/manual/1596099/Suzuki-Df70a.html?page=71#manual
That mentioned, do you own a digital multimeter? If yes, you'd then be able to measure for 12-volt power at the fuel pump wiring plug usually at first "key on" for say 2 or 3 seconds and/or engine cranking over depending on engine model and design.
