Location of manual relief trim valve on 1994 90HP force motor
ski24448
Trim/Tilt went out all of a sudden. Relays click and seems to be tilt motor after checking with meter. Can not find manual relief valve screw. Had 2 mechanics looking at it and so far no luck on being able to raise motor. Ser # OE032172
jerryjerry05
Pics f the T@T?? They used 2 different models.
More than likely you don't have a screw to release the pressure.
You'll need to loosen the first hyd. line you can see.
​3 days ago I had the opposite problem.
Mine wouldn't raise.
​I undid the front hyd. line and was able to lift by hand to install the trailer bar.
Make sure the grounds are good.
​My problem was inside the cap on the motor there is a points setup and it has the green lead connected/ soldered to it.
​The connection broke.
​The relays would work but the motor wouldn't spin.
ski24448
Thanks for response. Will try the lead hyd line as we replace/check leads on the trim motor.
Ski
