Location of the pressure control valve
gwseafarer
I own a 2003 Yamaha f225 4stroke<br />The manual says to check the pressure control valve every 200hrs. but I can't find it.<br />Can somebody tell me where it's located.<br />What does it look like?<br />What's involved in checking it?
rodbolt
Re: Location of the pressure control valve
no<br /> its top secret<br /> if I tell ya the men in tinfoil hats and black helos will be all over ya.<br /> a hint<br /> its not called a pressure valve in the parts list.<br /> I think its called a cover nut :) <br /> anyway another glass of this fine venezuelan rum and it may loosen my tongue :)
gwseafarer
Thanx again rodbolt.<br /> I'm looking for it now
rodbolt
hahaha <br /> ok ill tell ya<br /> but you have to deal with the tinfoil hat guys<br /><br /> to access the valve you have to remove the 5mm allen hex bolts from the port and stbd midsection covers on the aft edge. then gently pry them apart from the lower cowl. looking from behind the motor straight ahead you will notice a panel about 5" high by about 8 inches wide. that panel is help on by 2 more 5mm allen screws. remove them and the panel.<br /> now your looking at a 'shelf' with a 1 7/16ths hex nut with a locking plate.<br /> remove the 10mm hex bolt and lock plate and dont lose the spacer, remove the 1 7/16ths nut.<br /> that nut is the control valve assy.<br /> it cannot be serviced.<br /> grease the orings on the valve assy when reinstalling.<br /> I posted recently to someone on T-stst removal.<br /><br /> I hope the yamaha tinfoil hat guys dont get ya.
rodbolt
demon venezuelan rum :)
rodbolt
first one I ever did took a 10 minute useless call to yamaha then 30 min studying each picture in the microfiche.<br />no one knew were it was and the servive nonclementure and the parts nonclementure change.<br /> we know it as jinglish.<br /> another glass 0f this stuff and I am gonna speak vinglish :)
