Location of Trim/Tilt relays 1988 Bayliner Sierra Cuddy I/O 2.3L OMC Cobra
zigbat
The Trim up/down switch is in the control handle, the down works, up works sporadically but usually does not.
I have read that the problem is most likely one of the relays and they should be somewhere in the engine compartment in a box.
I have searched pretty thoroughly for the relays or relay box and havent been able to find it...
Does anyone know where it is located or if i am even on the right track..
Speak
I believe they are part of the trim pump assembly. Have someone work the switch while u listen at the back for the "clicking"
zigbat
I never did find the relays, but I did find the problem...
There is a 3 prong connection that connects the harness to the Solenoids and since it is a water resistant connection it is completely covered and difficult to tell whether or not it is fully plugged together..
It wasn't...
So from my only experience in this area I recommend check all connections starting at the power source all the way back, give the plugs a wiggle and a push before ya do any unnecessary surgery...
Thanks to you gurus and enthusiasts for all for the answers to all of our questions which I am sure get old and repetitive...
and to iboats for providing the forums.. and best prices on parts...
Speak
It wasn't...
Thanks for letting us know what you found.. Oh and welcome to iboats
