What is the small lever on the Port side of engine mounting bracket for? I note when engine is in down position this lever can prevent it from being lifted up and conversly let it be lifted up? what position should it be in when under power (locked to prevent being lifted) or unlocked, does it require to be locked to prevent engine lifting up when reverse is engaged? thanks for now JBD
