Loctite 081 grade D substitute…
ryanp1227
I am completely rebuilding a 1975 90hp Chrysler outboard, model 907HB. Upper main bearing calls for Loctite D to be applied to the outer surface during install. Would like to know of alternatives. I can not find grade D, and the Harnon equivalent I can only find on one international Spanish language website.
ryanp1227
jerryjerry05
Contact Loctite.
Consumer & Craftsmen Adhesives​
Technical Support: 800-624-7767
Industrial Adhesives, Sealants, and Surface Treatments​
Technical Support: 1-800-562-8483
dingbat
Loctite 081 orange threadlocker - tensile strength of 240 psi and a 72 hr cure time.
There are a number of products with the proper strength, but most are 24 hour cure.
I can only assume they spec’d 72 hours to allow adequate time for assembly
