Loctite on Starter Bolts?
MH9371B
Engine is a 1995 Mercruiser 3.0LX
Should loctite ever be used on the bolts when installing a new starter? I put a new one in a short while ago and the bolts have already come loose twice.
90stingray
Re: Loctite on Starter Bolts?
No. Crank them tight and you should never have a problem.
kewlkatdady
When you replaced the starter, did you reuse the original bolts?
ziggy
did ya use starter bolts? they have knurling on them. i assume to keep them from loosening...
when i removed my starter, i went to the local napa and they had some new ones for me in a blister pack right off the shelf..
MH9371B
I used the two bolts that came with the new starter
Ayuh,... Properly tightened, they shouldn't loosen...
If yer gonna locktite 'em, use the temporary stuff...
