Hello everyone,
Looking for the wisdom of others with regards to my 1996 mercruiser 4.3L V-6 motor, electric fuel pump, carbuerated. While out on the lake it takes 5-8 seconds of cranking time for the motor to catch. This seems like a long time (especially while the safety alarm is screaming at you). Is this normal for curbuerated systems when they've been working (wakeboarding/tubing/cruising) . When launching the boat the engine fires after only a couple seconds.
If I disengage the prop and start while giving gas, it will start quicker. This leads me to wonder if the engine is being starved although it runs fine under load.
Thanks for any input.
