Bigsurfstu
- May 18, 2009
- 1
I have a 1991 Wellcraft Eclipse 186 with a Volvo 290 I/O that was recently re-powered with a Chevy 350. The original motor was a 4 cyl. I found a good ski prop for the low gears: short hub 15x19.
I want to use a 15x21 for cruising, but it only comes in the long hub size. I have a 290 with a short shaft. I was given conflicting advice: one prop sales guy said I could use it if I remove the 3/4" hub spacer and secure the prop with the cone and the bolt that holds the cone to the shaft. It does fit. Another mechanic said that I should not do this because in reverse I could spin the cone off... This sounds far fetched to me. Any opinions? Many thanks!
