Re: long or short shaft
If you engine is sitting on a short shaft transom and hangs only two inches below the bottom, then you've got a SHORT SHAFT. A long shaft would be at least 20-inches. OMC's are typically a couple inches on the long side of 15-inches (or 20 for a long shaft) to account for variations in boat transoms, keels, etc. <br /><br />The only way your '73 model 25hp would be a long shaft would be if it had a 5-inch tall extension bolted between the exhaust housing and lower unit.<br /><br />- Scott
