Long shaft or short shaft?
bill3c6
I just purchased a 1978 evinrude 6hp 6804B. I was told it was a short shaft. I read that this motor was designed for salt water which leads me to beleive that it might be a long shaft. I was planning to use it on a 12 - 14 ft. boat. Can anyone tell me whcih it is. If it is a long shaft will I have any problems.
Your help would be appreciated.
JB
Re: Long shaft or short shaft?
You can tell from the (secret) model number or you can measure from the inside of the transom clamp to the av plate.
15" is a short shaft, 20" is a long shaft
bill3c6
JB,
Thanks for the information. I measured the distance from the top of the av plate to where the clamp sits on the transom. It measured 17.5 inches. I read somewhere else that a 15 inch could measure that long and a 20 inch could measure as much as 22.5 inches. Sounds like I may have a short shaft.
F_R
6804 is a 1978 short shaft
6805 is a 1978 long shaft
When they left the factory, that is. They often get changed in the field. The long shaft has a very obvious 5" extension piece above the lower unit gearcase. You can't miss it if it is there. If you don't see it, it is a short shaft.
